I have a 01 Jetta 1.8t.
Car will crank but won't turn over.
Only happens when it's "cool" out side around 75 or so and gets worse the colder it gets.
Starts right away when it's warm.
Tested spartplug battery alternator and starter. Every thing checks out
I did Some research and found that others with the same problem replaced the coolant temperature sensor.
Is there anything this else I could check?
Any help will be greatly appreciated.
Cts should have nothing to do with the starting of the car, I would check and see if you have fuel or spark during cranking
