I have an 01 jetta 1.8t and it has wiring problems. Whenever the lights are on the high beam indicator stays lit on the dash. Only one low beam will turn on even though both bulbs are fine and when i actually turn on my high beams both of the bulbs dim to almost nothing. I know it is a short some where in the system. Now should I go through and re-wire the whole system? If so where can i find the parts? Or if i just buy HALO LED's will that fix the problem?
Eur0wn3d
from reading a few things..some people had similar problems and traced it to their ignition switch so it could be that...changing your headlights wont really fix anything because the problems is further down in the wiring so you would just waste money and still have malfunctioning lights..unless u want to put an hid kit then that wouldnt demand much from the oem setup and probably solve your problem
