1 - 5 of 5 Posts
so my new to me jetta came to me with " minor" issue that seems to change everytime i "fix" something. currently my issue is that at random my CEL comes on and the car will lose some power ( almost feels like a misfire situation) the CEL code i keep pulling is 2214: engine over revved Rpm Signal.... this happens while im driving down the freeway (approx. 3k rpm) and some times even lower than that when im in town.
The repairs I have done so far: plugs, cap, rotor, injectors, MAF and crank shaft position sensor.
My question is what else can cause that code? thanks in advance
Over-rev is usually a transmission speed sensor. The RPMs appear to high
for how fast/slow the car is moving. ALso crank sensor, or wheel slip, or
clutch slipping on a manual.
However, the code you posted indicates an emissions problem, a NOx Sensor,
O2 sensor, not an over-rev code.
The 02214 VAG code is a tire pressure warning, you don't have TPMS.
http://forums.vwvortex.com/showthread.php?5113829-DTC-02214-Tire-Pressure-Warning
P0219 is engine over speed.
https://www.engine-codes.com/p0219_volkswagen.html
P1560 is also Maximum engine speed exceeded
http://wiki.ross-tech.com/wiki/inde...05472_-_17968_-_Maximum_Engine_Speed_Exceededhttp://wiki.ross-tech.com/wiki/index.php/17968/P1560/005472
So, I don't know what you're writing. The code you put doesn't match any
over-rev condition.
Discussion Starter #5
I guess i should post what my fix ended up being...
the hall sender in the distributor was the culprit. i just replaced the entire distributor, i picked a new 1 up for $73 through rock auto, and so far so good. I still have some small issues to deal with but its running like a champ.
1 - 5 of 5 Posts
