Hello,
Have a 1995 Jetta III 2.0. Timing belt broke. Replaced timing belt, V belt, Serpentine belt, distributor, cap, rotor, plugs, wires. Starts and Idles just fine but as soon as you step on the gas it bogs down and has no power. Have yet to get the codes off it as I am hesitant to pay the mechanic $95 just to plug in their OBD1 code reader. Hoping to find one some place else. I am getting good compression (140 psi) on all cylinders. Engine light is on. Doesn't seem to have a vacuum leak but some of the lines are old and probably need replaced especially after removing and installing the plugs so many times. So my thoughts are vacuum leak, some sensor not functioning, or fuel injectors. Any thoughts on process of elimination?
