Technical Characteristics:
Common rail injection system with Piezo fuel injectors
Diesel particulate filter with upstream oxidation catalyst
Intake manifold with flap valve control
Electric exhaust gas return valve
Adjustable exhaust gas turbocharger with displacement feedback
Low and high pressure Exhaust Gas Recirculation (EGR) system
2.0 Liter TDI Technical Data
Design 4-Cylinder In-Line Engine
Displacement 120 in3 (1968 cm3)
Bore 3.189 in. (81 mm)
Stroke 3.760 in. (95.5 mm)
Valves per Cylinder 4
Compression Ratio 16.5:1
Maximum Output 140 hp (103 kW) at 4000 rpm
Maximum Torque 236 lb-ft (320 Nm) at 1750 rpm up to 2500 rpm
Engine Management Bosch EDC 17 (Common Rail Control Unit)
Fuel ULSD / ASTM D975-06b 2-D-S<15 (Ultra-Low Sulfur Diesel, under 15 ppm)
Exhaust Gas Treatment High and Low Pressure Exhaust Gas Return, Oxidation Catalytic
Converter, Diesel Particulate Filter, NOx Storage Catalytic Converter
The 2.0 Liter TDI common rail engine uses a forged crankshaft to accommodate high
mechanical loads. Instead of the customary eight counterweights, this crankshaft has
only four. Using four counterweights reduces the load on the crankshaft bearings, as well
as noise emissions that can occur due to the intrinsic motion and vibrations of the
engine.
The 2.0 Liter TDI common rail engine pistons have no valve pockets. This reduces the
cylinder clearance and improves the swirl formation in the cylinder. Swirl is the circular flow
about the vertical axis of the cylinder. Swirl has a significant influence on the mixture formation.
For cooling the piston ring zone, the piston has an annular cooling channel into which
piston spray jets inject oil.
The piston bowl, where the injected fuel is circulated and mixed with air, is matched with
the spray pattern of the injection jets and has a wider and flatter geometry than the
piston in a pump-injection engine. This allows more homogeneous carburation and
reduces soot formation.
The 2.0 Liter TDI common rail engine has a crossflow aluminum cylinder head with two
intake and two exhaust valves per cylinder. The valves are arranged vertically upright.
The fuel injectors are fixed in the cylinder head with clamps. They can be removed
through small caps in the valve cover. An additional feature of the cylinder head are
pressure sensors that are integrated into the glow plugs.
Two intake and two exhaust valves per cylinder are arranged vertically suspended in the
cylinder head. The vertically suspended and centrally situated fuel injector is arranged
directly over the center of the piston bowl.
The two overhead camshafts are linked by spur gears with an integrated backlash
adjuster. They are driven by the crankshaft with a toothed belt and the exhaust
camshaft timing gear. The valves are actuated by low friction roller cam followers with
hydraulic valve lash adjusters.
Shape, size, and arrangement of the intake and exhaust channels ensure a good degree
of fill and a favorable charge cycle in the combustion chamber.
The intake ports are designed as swirl and fill channels. The air fl owing in through the fill
channel produces the desired high level of charge motion. The swirl channel ensures
good filling of the combustion chamber, particularly at high engine speeds.
Intake Manifold with Flap Valves
Infinitely variable flap valves are located in the intake manifold. Through the positioning
of the flap valves, the swirl of the intake air is adjusted based on the engine speed and
load.
The flap valves are moved by a pushrod connected to the Intake Flap Motor V157. This
step motor is activated by the Engine Control Module (ECM) J623. The Intake Manifold
Runner Position Sensor G336 is integrated in the Intake Flap Motor V157, and
electronically regulates its movement. It also provides the Engine Control Module (ECM)
J623 with feedback of the current position of the flap valves.
During idling and at low engine speeds, the flap valves are closed. This leads to high swirl
formation, with results in good mixture formation.
During driving operation, the fl ap valves are adjusted continuously based on the load
and engine speed. Thus for each operating range the optimum air movement is available.
Starting at an engine speed of approximately 3000 rpm, the fl ap valves are completely
open. The increased throughput of air insures good filling of the combustion chamber.
At startup, during emergency operation, and at full load the flap valves are opened.
engine.
load.
