Hey everyone,
I have a 2000 Jetta that doesn't blow cold AC. I would classify myself as a beginner when it comes to car repair and wanted to see if anyone had any thoughts on this. Here are the details:
- When the AC is turned on, air does blow through the vents. Each setting (1-4) does blow harder than the previous.
- Both front fans spin and are working
- The AC compressor clutch never engages
- All fuses (two inside the car and the one above the battery) have been replaced and test good.
- When the AC is on full blast, the voltage coming from the AC compressor wire shows ~9.3V for about 5 seconds, then jumps up to about ~11V for less than a second, this repeats over and over and the clutch never engages.
Does anyone here have any idea what the next logical troubleshooting step would be? I've read about this possibly being the fan control module (maybe) and also read about testing the AC compressor using an external 12V power supply, but am not sure where to go from here. Thanks!
