Car details: 2001 mk4 jetta gls 2.0 4 cylinder automatic 130k mileage
Issue: This afternoon i started my car just like any other time, started driving and as i left off the gas a metal rattle sound appeared. The sound only occurs when either the car is in park and idling, or when i let off the gas. As soon as i put any pressure on the gas the rattle immediately goes away. I haven't been able to get under to check for loose mounts, or a heat shield (will do in the morning and post an update). So far before starting the car i checked all my fluid level, which were all good, my belts are good, no play in the alternator, or steering pump. Then i started the car and did a walk around to try to pin point an area where the sound is coming from, and it sounds like in the area around the flex pipe/fire wall , in the middle of car. I have googled and checked countless threads but can only find issues for manual trans., and turbos. PLEASE HELP!
