Hit something and cracked the oil pan. I assume that the oil pressure switch made the car beep 3 times and shut down as the oil level went down. Hauled the car home, replaced the oil pan, pressure switch and car just cranks. Replaced the M109 relay, Crank position sensor, checked injectors and had fuel, checked the timing, checked compression and ran the VAGCOM system diagnostics with no codes or issues. Car still won't start. Any ideas before it goes to the bone yard?
