Hello all new here hopefully someone can help me figure this turd out. Do my issue is the randomly won't start it I left it sit overnight. It runs great when it does no check engine lights or anything like that I've had the car alittle over a year now and never had any major issues with it. So here's my issue now that it's winter when it gets below freezing the car won't start cranks over great but no fire Fuel pump does not prime. I tested the pump it does prime when I pull the relay and put it back in with the key turned to accessory. I just put a brand new battery in in today and a new crank sensor also replaced the ignition switch still no luck. When I bought the car it would not shift out of 1st the solenoids were bad to I replaced those and did a water pump and timing belt while I was at it. Never really had a problem with the car til now I scanned the codes and it has p1850 stored it will not clear but that shouldn't cause the car not to start. I also noticed that when trying to turn the car over sometimes I have to turn the key more then 1 time for the starter to engage I assume the starter is going bad still shouldn't affect the car from firing up. I'm at wits end I've dumped a ton of new parts spent alot of money on parts for it reading forums and trying to figure this thing out. I have a fuel pump relay coming which should be here this week but I doubt that will fix it. If any one can help point me in the right direction that would be great. If anyone needs more details please feel free to ask its may daily driver and my other car has 400whp and I don't wanna drive it in the winter. Is there any module under the dash that could cause an issue like this I feel that it only started doing this when I parked my car on a hill and water ran from under the dash so something must have gotten wet under there and when it freezes it shorts out.
