1 - 1 of 1 Posts
My 2003 Jetta continues to run after turning off the key. I replaced the ignition switch module and have eliminated the mechanical part as a issue. If I pull both battery cables and hold them together for a couple minutes and reconnect them, the ignition will shut off the engine a couple times and then revert to the problem.... HELP!
1 - 1 of 1 Posts
