I have seen a few similar stories to mine and I think I have a handle on it but I would like some more feedback. Problem: My left turn signal works fine, my right turn signal flashes rapidly. If I am driving down the road without blinkers on and I step on my brake, the right turn signal on the Instrument Cluster (the green arrow) comes on very dim. I have checked the bulbs which are working fine and the terminals which are clean. Flasher relay? if so, where exactly is it? Ground issue? Thanks for the feedback!
Discussion Starter #3
Yes, but I found the problem. I have aftermarket tail lights and the problem is in the aftermarket connector. If I wiggle the ground wire, the problem temporarily goes away. I'm just going to order a new connector from SONAR. I appreciate the feedback
