My 05.5 shifts hard in all gears, but only about half of the time. Several times a week it gets stuck in a random forward gear, and wont shift. The shifter won't engage manual shifting either when it does this. If I pull over, turn off the engine, and wait about 30 seconds, the transmission functions again.
I'm thinking it's an electronic issue because it resets itself upon starting. It may be helpful to know that the transmission was pulled to replace a stretched timing chain about a year before the problem started, and my dealer did a crap job. They forgot to tighten some bolts on the suspension when it was put back together, and it took about 6-8 months for the bolts to loosen enough to cause a noticeable problem. in addition to trashing my control arm bushing, it needed transmission mounts replaced. The dealer wouldn't accept responsibility, so I have no faith that the transmission and whatever else they removed was reinstalled properly. Constantly replacing fouled spark plugs since that event too.
Anyone had a shifting issue like this before? Thanx
