1 - 5 of 5 Posts
If it doesn’t work on any setting it needs a blower motor or it might be the fuse or relay but the resistor slows the motor for the lower settings
where is the fuse and rely located
Not 100% sure on the MKV check the owners manual if you have it if not chilton’s books are at the local parts store and well worth the $$
Alldatadiy is 10x better than chilton/hanes. Like trying to follow directions your drunk uncle gave you compared to plugging an address into gps… “soooo when you get to like the third maybe 4th exit you should see a tree go left at the second white fence and…uhh. Honk when you get here. Ill come outside to wave you in…”🙄
1 - 5 of 5 Posts
