Status
Not open for further replies.
1 - 16 of 16 Posts
Hello all,
Ive been buying mk4's for awhile now and have alot of left over parts to get rid of for a low price just to get them out of storage. discounts when purchasing multiple items is available to make quicker sales! this thread will change as things are no longer available and i take pics of other items.
Items are preferably picked up in MEDFORD, NJ 08055 (not far outside of philadephia).
Shipping is extra and is calculated per customer(zip code) and per order(size/weight).. its usually more expensive then the part cost:screwy:
PAYPAL ACCEPTED :thumbup: ( 3% paypal fee will be added to orders)
If you feel prices are unreasonable, please pm me with a valid reason / example of lower prices and i will work with you to make the sale happen!
Please feel free to pm me with questions or for quickest response text my cell phone number 609-784-4900
Thanks, Garrett:wave:
I have all my parts box'd up in storage so i will be removing everything from the box's and taking pictures of the parts inside with description, part number, price, etc.
Majority of the parts are leftovers from two mk4's (2001 golf 2.0-manual with 68k /1999.5 jetta 2.0-auto with 137k) making all these parts Genuine OEM quality and not ebay replica quality.
---FOR FITMENT LOOK UP THE PART NUMBER---
All parts for sale are listed below:
BOX #4!
1)JETTA RIGHT TAILLIGHT # 963685- $15
2)Tail light circuit board bulb holder VW Jetta 00-05 OEM 1J945257 (2count) -$10 each
3)air pump emissions 06a959253b -$30
4)Battery Tray OEM 1JM 915 333 -$15 (with battery hold down clamp)
5)TRUNK HINGES left and right 3B5827301A/302A -$20
BOX #5! (engine bay/interior):
1)WINDSHIELD WIPER RESERVOIR 1J0955453F/G -$10 (with fluid level sensor, cap, and fluid motor)
2)Genuine Ignition HT Lead Cylinders 1-4 06A035255C -$15 (with wires)
3)Radiator Overflow Expansion Tank 1J0 121 407F (2 count) -$5 for the one without the expansion top and $10 for the Reservoir fluid Tank Cap 1J0121321B
4)Crankcase Vent Valve PCV, 06A103465 -$5 (with cap)
5)RIGHT PASSENGER SIDE FRONT POWER WINDOW SWITCH 1J1837114 -$10 (with handle and locking switch)
6)Power Steering Reservoir 1J0 422 371 C- $10 (with cap)
7)Grey Left or Right Grab Handle w/ Screws (2 count) 1J5857607B -$5each
8)GLI CHROME STRUT TRUNK SHOCK SUPPORT DAMPER 3B5827550E (2 count) -$10each
9)BOSCH Mass Air Flow Sensor MAF 0280218002 -$15 (with sensor housing)
10)Headlamp Switch 1C0941531B01C -$15
11)Passenger Right Tweeter Speaker 1J0035411 -$10 (with housing/ screen and wiring)
12)Throttle Body Valve TBI 06A133066E -$30
13)Fuel Gas Cap 1J0201553A -$5
14)fuse box cover 1j010227h -$5 (with card)
15)MASTER POWER WINDOW LOCK SWITCH 1j4 959 857 -$10
BOX #6! (small parts):
1)COMFORT CONTROL MODULE CCM ALARM 1J0 959 799 AJ -$25 (with harness connections and some wiring)
2)Fan Control Module Relay OEM 1J0919506H -$20
3)AUTOMATIC TRANSMISSION SHIFTER LOCK RELAY #175. 3A09271810 -$5
4)HEADLIGHT RELAY #173. 3A0941589 -$5
5)Multi Purpose Relay #100. 7M0951253A -$5
6)Close Contact Relay #185. 3B0911251 -$5
7)Wiper Control Unit Relay #377. 4B0955531A -$5
8)Clear Side Marker Turn Signal Repeater Light 1J5949117A -$5
9)Fuel Gas Door Release Switch 1J0959833A -$5
10)Trunk Release Switch 1J0959831A -$5
11)Button Defrost Switch OEM 1J0 959 621 D (2 count) -$5each
12)PURGE VALVE/THRUST RING 535133459 -$10
13)Ambient Air Temperature Sensor 1H0959625 -$5 (with harness connector and some wiring)
14)IN-DASH BLANK DELETE SWITCH DELETES COVERS 1J0858180C01C (3 count) -$5each
15)Brake Pedal Stop Light Switch 1C0945511 -$5
16)retainer 1J0422162N-$3
17)Shifter Linkage Cable End Bracket (Automatic) 01m321397c -$5
BOX #2
1) Sunroof Sun Roof Motor 99.5-05 VW Jetta Golf Beetle Passat MK4 - 1J6 959 591 -$20
2) alarm horn siren 1jm 951 167 a -$10
3) e-brake handle and assembly 1J0 711 303 -$30
4) gray rear view mirror 3b0 857 511 -$10
5) 1999-2005 Mk4 Volkswagen Jetta Passenger Front Seat Belt OEM Black 1J4 857 706 L -$85 for all 4
6) SUNROOF SWITCH CONTROL VW JETTA,GOLF,GTI,PASSAT MK4 99.5-05 1J0 959 613 E GREY -$10
7) 98-05 VOLKSWAGEN PASSAT 1J0 820 045 F CLIMATE TEMPERATURE CONTROL UNIT A/C HEAT -$25
8) Fuse panel covers -$5 each
9) 3B0 857 552 A B 99 05 VW GOLF GTI JETTA RH PASSENGER SUNVISOR SUN VISOR TAN -$10
BOX #3:
1) Passenger Side Airbag. 1J0 880 204 K -$20
2) Volkswagen 1.8T MAF Sensor - OEM part number: 06A-906-461-LX / 06A906461LX, used -$20
3) Coolant cap 1j0 121 321 B- $5
4) Coolant connectors 1J0 129 291 D/1J0 122 291 B -$5 each
5) VW MK4 GOLF 98-04 BOOT COMPARTMENT ACCESS PANEL COVER 1J0 867 468 1J0867468 -$10
6) Upper Inner Audi 80 90 VW Engine Timing Cover 048 109 173 A -$5
7) VW Jetta Golf Beetle 2.0L Ignition Coil UF484 06A905097 -$30
8) Door Latch Cable used OEM 1J4 837 085 D10/99 -$5
I'm only saying this since this guy hasn't been here for a while but I have a full set of all red tails if you want them for cheap
Thats a good price but I can't pic them up, I'm guessing it's gonna be another $20 for shipping, let me see what I can find and i'll let you know. Thanks
I'm still interested, could you check with the post office to see what shipping would be to zip 26159, thanks, if you have any questions you can also text me at 304-771-4874, thanks again
yep, I'll have to do it tonight, I'll shoot you a txt when I get the quote
Do you still have parts? I'm looking for the driver's side window motor/module. I need either just the module attached to the motor, or the whole assembly. No need for the actual motor, but if it's there it's there.
1 - 16 of 16 Posts
Status
