Hi - my clutch pedal is stuck to the floor. I have CABLE (not Hydraulic) to mmove clutch lever so I replaced that thinking it was damaged. Same problem. I also replaced the throw out bearing with no results. I removed the clutch push rod and inspected it and it looks fine so I just put it back in - did not replace that.
Does this mean I need a CLUTCH? If so how hard is that - is there a DIY on this?
thank you
thank you
