Is there any way to test if my car's crank sensor (AKA engine speed sender) that works with the RPM's is OK or faulty??
Apparently OBD 1 code 2111 refers to this sensor, but I got notice that this code will be thrown by the car's computer if it tested with the engine off, but my car doesn't start and I need to find a way to diagnose this.
Any help??
Thanks
· Premium Member
Before testing this sensor, you should be sure you are getting spark and the distributor is in time. Also, get a noid light or an injector pulse detector to see if the injectors are operating. If they are, you have a good crank signal.
Even if the cam sensor is bad, it will still start as it opens all the injectors at teh same time so there won't be a problem there.
Hi!
Thanks for your help!
I have spark at the ignition coil, but I'll have to check the distributor...
The car will crank OK, but it will not start.
****This morning it started for the first time. Very weird, it kept the RPM's around 200-300, stalling like crazy. There was a heavy unburned fuel odor. I tried accelerating slowly and when it was about 450 RPM's, it got worse. I heard all the relays clicking going on/off under the steering wheel, so I switched the engine off...
Could it be the distributor?
Any other ideas??
Thanks again!
