1 - 8 of 8 Posts
AllShoNoGo
Your heatercore is located under the dash, behind the centre console. Check with your local dealer, and see if it is covered by a recall. It's a very big job,if it isn't, but if you're up to it here's a check list of how I do it.
1. Remove the heater hoses, under the hood at the firewall 2. Remove two nuts under heater hoses. 3. Loosen third nut behind throttle(if you have A/C. 4. Remove centre console, shelves under steering wheel and glovebox. Centre air vent, air duct to that vent, and bottom rear duct (screw beside gas peddle and at passenger side. 5. Disconnect three heater cables at heater box. 6. With a long phillips screwdriver remove upper air duct. 7. Remove the clips (6 or 8)splitting the heater box vertically into left and right. There are two tough ones at the back, inserting a flat screwdriver and twisting releases them. Practice on the front ones, that are visible 8. Remove the left half that contains the heater core.
Changing heater cores isn't easy, and will require patience...
P.S You might want to put down some towels and a piece of cardboard on the passanger floor to stay dry. Removing the passanger seat may make it a little easier as well. Good Luck
AllShoNoGo
never had to do one yet...:D
Anybody have a write up with pictures? I'm new to VW's and trying to do it myself. I've got the console out parts of the ducting system. Trying to get the 2 bolt in the firewall but one of the bolts started to spin. Then after that don't really know where to go
For parts at low prices should checkout autohausaz.com picked up oem heatercore for 20.00. BTW what
trick to removing the ducting to get to the heatercore?
i deleted the A/C and heater in my mkii...i thought it was pretty damn easy...and the only thing that cost was a coupler for the hose($2) and toywagens A/C pulley($65) plus all that crap weighed 75+lbs when i took it to recycle the metal
1 - 8 of 8 Posts
