AllShoNoGo
taken from another site..
Tools needed:
  1. 8mm socket.. ¼” screwdriver-type handle is useful on this
  2. 10mm shallow and deep sockets
  3. 13mm socket
  4. XXX torx driver
  5. Phillips screwdriver
  6. wire cutters
  7. ¼” drill bit and drill
Parts needed:
  1. new heater core
  2. a bit of coolant
  3. 2 new steering wheel bracket shear bolts (N 905 422 01)
  4. zip ties
  5. ¾ ” plastic plumbing elbow as a temporary heater core bypas
  6. a couple of screw-type clamps... the factoy spring clamps won't quite be tight enough
Some shortcuts that worked for me:
  • NO NEED to drain the cooling system… just work quick to plug the heater hoses with a ¾ ” plumbing elbow
  • NO NEED to vent/disconnect the air conditioning… with everything loose you can wiggle the heater core end of the heater box just enough to get the heater core out with the rubber part of the A/C hoses taking up the flex.
  • NO NEED to remove the rebar. Loosening it and dropping the passenger side down is enough and saves some wiring disconnects on the driver’s side
  • NO NEED to disassemble the heater box…as above, the secret here is to loosen everything and then pry carefully on the heater core side. Leave the heater box clips alone !!
Under the hood:
  • disconnect the negative terminal of the battery
  • remove the two piece plastic gutter guard
  • remove the windshield wiper arms and motor assembly
  • remove the two heater hoses… working quickly, plug ‘em with a ½ inch plastic plumbing elbow as a temporary bypass
  • (air conditioning) remove the vacuum hose in the middle of the two heater hoses
  • (air conditioning) remove the two 10mm nuts securing the air condenser side of the heater box to the firewall. These might be there for non-airconditioning boxes as well… dunno ‘cause I have air.
  • remove the two 10mm nuts securing the heatercore side of the heater box. They are behind the metal heatshield glued to the firewall. One is accessible thru a tab in the heatshield down by the tin heatshield for the brake line, the other you will find by prying the metal heat shield away from the firewall by where the heater hoses come out.
  • remove the two 10mm nuts that secure the front of the dash to the rain gutter. This is why you removed the windshield wiper motor… one of them is blocked by the motor.
  • remove the 10mm nut that secures the rebar to the firewall. This one is below one of the 10mm nuts that secures the dash by where the windshield wiper motor used to be.
Inside the car:
Remove the dashboard:
  1. remove the steering wheel, ignition switch cover, and both control stalks
  2. (diesel) unscrew the cold start knob bracket and loosen the cable from where it comes thru the dash. I trimmed the bottom of the hole in the dash to make it easier during reassembly.
  3. remove all dash fascia: glove box, knee panels, dials, switches, cluster, etc etc etc. The heater controls do not need to be disconnected.. let ‘em dangle.
  4. remove the plastic emergency brake housing
  5. remove the centre console.. I found I needed to remove the two 13mm nuts that bolt the emergency brake handle down so that I could push the handle out of the way… others seem to know how to wiggle the console out with the handle in place.
  6. disconnect all remaining wiring from behind the dash. This includes speaker connections, lighting connections to the passenger heater vent, and several grounds.
  7. loosen all wiring secured by plastic wiring clamps attached to the dash or heater box. There are a bunch of them on a row below where the cluster sits, one by the headlight switch, and several on the passenger side. I found the factory had looped the speaker wiring around the one of the two dash mounting brackets and I had to snip it. Note the wires zip-tied to the top of the blower fan assembly… snip snip goes the zip-tie.
  8. remove all remaining dash mounting bolts. These are 8mm bolts: several in the vicinity of the steering wheel, a couple under the centre console, and several by the passenger side. There are also one each on the extreme left and right lower sides of the dash, by the door jams.
  9. slowly and carefully, pull the dashboard out of the car… checking for wires that are caught etc. It is not a tight fit and should come out easily… if something binds stop and figure out why !!
Loosen the ReBar:
  • remove the four big torx bolts that secure the sides of the rebar to the car… they are accessible from the driver and passenger side door jam.
  • remove the four 13mm nuts securing the reinforcing plate that goes between the centre console hump and the rebar
  • remove the two 13mm nuts that secure the front of the pedal cluster bracket to the rebar.. this is the only part of the job where you may need to stand on your head to see ‘em initially.
  • drill out the two shear bolts that attach the steering wheel column to the rebar… trust me, this is quicker than grinding them down or trying to grab them with vicegrips
  • remove (or snip) the braided copper ground clip on the passenger side of the rebar
  • working from the passenger seat, pull out the rebar on that side and lower it to the floor
Loosen the Heater box:
  • remove the two small black tubes that funnel heat into the centre console channel… one Phillips screw each.
  • remove the big white plastic plenum at the front of the heater box… two 10mm plastic nuts
  • remove the smaller black plastic plenum at the front of the heater box… one Philips screw
  • cut the big plastic ziptie that wraps around the entire heater box assembly on the passenger side
Remove the damn heater core:
  • (air conditioning) remove the rubber vacuum hose from the heater core
  • remove the star screw on the center of the dash that keeps the sound damping in place and then pull the sound dampening out of the way… you’re going to need every inch.
  • using a piece of broomstick, 2x2 etc, carefully pry out the heater-core side of the heater box so you can access and remove the Philips screw that holds the heater core in place.. Go slow… this is in fact a tight fit. The plastic vent that blows hot air at the drivers feet will want to bump against the rebar… you may have to move the rebar out a bit further.
  • FINALLY: pry further on the heater box with your wooden stick and pull the old heater core straight up and out. Very very tight fit at this point as the hose connections will just clear the dash and window… nice if you obtain another set of hands for this one final step.
  • obtain a steam roller and run over the stupid heater core repeatedly while giggling insanely like Chief Inspector Dreyfus from the Pink Panther movies.
Notes on reassembly, which is of course pretty much the reverse of disassembly:
  • the leaking core probably filled the bottom of the heater box with coolant… I was able to reach in with several rags and mop it up. Prevents even more greasy steam on your windshield.
  • good idea to fill the new heater core with water as a test… I’ve seen at least one report of a new core leaking.. man would that suck or what… nobody should ever have to do this job twice ??!!
  • I had to remove the black plastic cover on the bottom of the new heater core to get it to fit… did a bunch of measuring and convinced myself that I had a slightly wrong part that would never fit down all the way. Some weather stripping tape was required to get the bottom to seal.
  • note the two black plastic sealing washers on the two studs that hold the dash to the firewall… according to the Bentley they’re very important and need to be there when you mount the dash back in place.
  • My hands were too large to fish up and reconnect the speakers, so I pulled the grill covers and speakers and fed the wires up to the top of the dash
  • Rattling dashboards are a pain.. make sure things go back together tight and secure all wiring within the stock clips or additional zip-ties
  • I found it helpful to reassemble big items like the heater box, rebar, and dash to the point I could loosely bolt on the firewall bolts and then work inside the car to push things in place, carefully checking for interference, etc. The final step would be to then tighten the firewall bolts.
  • I temporarily replaced the two steering wheel shear bolts with normal hexheads but promise yourself to order proper shear bolts from the dealer… according to the Bentley Service Manual they are designed to shear off in the event of an accident... sounds important to me! I filed flats on both of the new ones before installation so that they can be easily removed the next time... hopefully never.
  • the rebar has four adjustable spacers that the big torx bolts run thru.. donuts with grooves and a left-hand thread… looks like the factory uses them to get the rebar centred between the door pillars. One fell out as I loosened the rebar and it took a while to figure out what it was when I found it on the garage floor later.
  • run the engine for 3-5 minutes with the filler cap off, allow the engine to cool, and then top up the coolant.
  • on my car the sound damping dropped down a bit after I have everything back together and rubbed against the top of the throttle lever.. causing me some anxious minutes during my test drive until I figured it out. If I had to do it again I’d use some weather-stripping adhesive or the like to glue the sound damping back in place very securely.
I'm glad you decided to write this DIY for the Jetta community. It's one of the most complete ones out there. I have a question though about the rebar removal. Once you take the two torx bolts out on each side you can see pinch clamps. I was wondering if these need removed too and if so what the best possible way is to do it. Right now the rebar is loose but still not coming off.
GLX Noob
Ty For Writing this very thorough Step by step I would have no idea how to take the heatercore out and i need to do it this weekend u saved me a few hundreds dollars from having to take the car to a shop after getting pissed off
