Any instructions out there on how to change the axle seals on the DSG?
My passenger side one is leaking, and slinging fluid under the car. Not a very bad
leak, not yet.
Apparently, they know this can happen, as there is a rounded shield above it to keep the
fluid from slinging up into the engine compartment.
I did some research, and from what I read, you only have to remove the shaft
bolts, pull the axle and replace the seal, and you can do it without pulling the trans.
I may as well replace both seals if I am going to do it...
leak, not yet.
