Hi,
I just recently purchased a 2015 MKVI Jetta S, I'm not looking to do many (if any) performance mods on it, seeing as its just the base model. But I am trying to change out the stock rims on it, but I'm not sure if the tire/wheel combo I want will fit. I currently have 6Jx15 wheels on it, with a 50mm offset. and 195/65r15 tires. I would like to put on the Focal F04 wheels, which are 7.5 inches wide, with a 48mm offset, and put 225/45r17 tires on them. According to willtheyfit.com the new wheel/tire combo will be 17.1mm closer to the suspension and will poke out 21.1 further on the outside. I know the diaper will be the only slightly off, effectively the same, but I'm just not sure if the new dimensions will fit inside of the wheel well. Any insight?
Thanks!
Should fit no problem.
