1 - 7 of 7 Posts
Has anyone converted their VW with an electronic injection pump, over to an older, manual pump?
I was looking at my 2002 today and was puzzled by the fact that there is only one injector that has a wire going to it. What's the deal with that?
But will an older, manual pump bolt onto a 2002 Golf without a lot of hassles? And what about the injectors?
I am convinced that's the way to get good mileage out of it and it will eliminate all the electronic garbage.
you then have a wiring problem, there should be wires going to each injector, they all have plugs for them correct?
Discussion Starter #5
The car has ONE injector with a wire going to it. The others do not and there isn't any other wire on the injectors.
And the car runs great and gets right at 40 mpg.
I have been told here that this is a manual injection pump so why should the injectors need any wires going to them? My Dodge truck doesn't!
Send me a photo of your Mk4 with a wire going to every injector........ [email protected]
This is not my car but it's the same motor, here you see all 6 fuel injectors have wires going to them
now that I look and see what section this is posted in, and that the motor was never stated it seems to be a TDI, that answers a lot of questions then
1 - 7 of 7 Posts
