2006 VW MK5 Jetta 2.5L Turbo 5cyl 07k 034Motorsport Car $11,200 asking
This is a rare setup and one of a kind 034 turbo kit, lots of hardware went in to building this car. It's an amazing car to drive and super fun. Makes good power 350whp at 15psi on a mustang dyno, same as a stage 3 b5 s4. So if you want something that handles very well, and fast. This is great start. Track car, street car, currently daily driver with two car seats in the back. Let me know what questions you have, but you can't build this car anywhere near this price tag. Tons of work done in last 1600miles. Parts and work listed below. Email me for more photos or to see the car bucket.racing@gmail.com
Will ship the car as well to a good home.
Build photos and others here:
http://s174.photobucket.com/user/bucketracing/library/2006 VW MK5 Jetta 07k Turbo
109k miles on chassis, car was turboed at 80k on chassis.
New motor with 62k miles went in when turbo was installed 9.5:1 compression ($600)
New valve cover, oil cooler, and misc gaskets installed ($72)
New water pump w/ accy belt installed ($65)
TT-RS spark plugs ($12 per plug)
Red OEM coils w/ fire sleeve wrap on harness ($28 per coil)
Rerouted water system,w/deletes
Block breather setup with filter ($40)
Rerouted vacuum lines, evap, etc ($70)
Wrinkle coated valve cover
Rerouted washer nozzle w/ tuck harness.
Turbo kit: 14psi 350whp on mustang dyno (kit cost $6000+)
5858 Precision Billet wheel turbo (GT35 size with faster spool)
034Motorsport tune w/launch control 4krpm
550cc injectors w/repined harness connector ev-14
46mm Precision wastegate
034Motorsport billet piston bypass valve
034Motorsport intercooler plumbing/ inlet piping.
034Motorsport Maf housing w/adapter harness & intake temp sensor
Garrett Large core intercooler/ with bracket etc
AEM dry filter
034Motorsport stainless steel cast manifold vband (only one made)
3.5" Vband downpipe and midpipe
Full AN oil feed & drain lines
Full T-bolts on everything or Ideal clamps.
Hallman pro manual boost controller. ($98)
3" Eurojet vband exhaust axle back before is 3.5" to turbo ($600)
IE intake manifold (customer powdercoated) ($1000)
IE billet fuel rail ($110)
AN fittings w/black braided hoses for evap, fuel, etc ($65)
Southbend Stage 3 Endurance clutch with steel flywheel 1600 miles ($950)
New shift fork w/ throw out bearing & pin ($25)
Forged flywheel bolts ($80)
Wavetrac with rebuilt transmission, new gears, bearings, seals, gaskets. ($2000+)
034Motorsport shifter bushings ($50)
Both front axles brand new ($300)
New control arm bushings Poly ($60)
New sway bar end links oem ($30)
034Motorsport prototype transmission mount street density ($124)
New oem dogbone arm ($40)
034Motorsport dogbone pucks 60 durometer full rubber. ($60)
034Motorsport subframe locking collars prototype ($120)
Coilovers K-sport customer valved w/ Eibach springs & camber plates ($1300)
034Motorsport rear adjust spherical control arms ($325)
H&R 28mm rear sway bar ($200)
034Motorsport rear end links ($165)
034Motorsport trailing arm bushings ($250)
Brembo 17z front brake caliper upgrade w/coated slotted rotors ($550)
034Motorsport stainless braided brake lines w/ Teflon coating TT-RS ($120)
New Bosch brake pads,w/hardware etc. ($110)
12mm Spacers up front wide track ($45)
New oem front wheel bearings both. ($148)
New rear oe brake rotors w/ textar pads ($180)
New Hankook V12 tires
17" Sparco wheels (superlight)
034Motorsport 2.5" stud & lug kit ($70)
Touch Screen Kenwood double din with Bluetooth, ipod, etc ($500+)
Extras included like boost gauge with steering wheel pod
Multiple front grills
AEM dry filter
