have a 2012 Jetta 2.0 gas. Last year I had the EPC light and check engine light on with the car sputtering and not getting up to idle. I had the shop repair the problem which was a fuel injector. Well seems I’m having the problem again. I took it to oreillys and ran the obd code and it’s misfire cylinder 1 and 4. I’m assuming it’s another fuel injector.
I’ve looked all over the internet and cannot find a place a diagram that shows me what number cylinder is each fuel injector
when you’re looking at the engine from left to right what are the numbers of the fuel injectors?
Thanks
I have a 2016 and inline should go 1-4 from the from of the engine (where your belts are) to the rear. The injectors follow the same order as the 2.0 is direct injector.
