Having trouble finding a correct fuse diagram for this 09 Jetta 2.5L I was going through the fuses just checking and realized that they were off from what the owners manual says so fixed it to the book then couldn’t start the car so any important input
Did you search for a fuse box diagram? Hopefully someone has the same car and take a picture and post it for you.
Always take s picture from your work BEFORE you start changing/working! It’s saved me on numerous accounts regardless of the simplicity/complexity of the work.
Edgar was the reason you changed/manipulated fuses in the first place? Describe what you by car doesn’t restart.
No start/no crank?
Start/no crank?
Start/cranks but no turn over ?
I got it to start but all the bells and whistles came on but you turn the key then nothing.. So after I got it to start started driving down the road and had a O2 sensor P0030 code pop up. Which I have just replace that two months ago OEM sensor and so I just don’t know what exactly is going on yes you’re absolutely right we taking pictures though
