Headlights issues
1062 Views 1 Reply 2 Participants Last post by  woopsIfarted
Not sure I am posting on correct forum so please direct if not.
vehicle is 2006 Jetta turbo, A/T, 4 door. My daughters car.
hitting the brakes the lights go out, hitting a bump in the road, lights go out.
I have checked the very basics, the battery is 12.38 before starting, the alternator output is 14.28, terminals clean.
I pulled the main lighting switch but don’t see any obvious defects, nothing noticeable like loose or heat.
Looking at different write-ups on the internet I replaced the ignition switch because this was known to cause strange electrical problems. No change except spending $40.00
It’s a nice little car, plenty spunky and I really need to figure this out.
thanks in advance
Hi, I'd let it idle and shake the battery cables. Sounds line corroded or looses ground to body. Good luck.
