can someone explain why my thread was deleted please
I can't explain it for you, it has happened to me a few times too.can someone explain why my thread was deleted please
Maybe.thnx mate,,I was really hoping to get some help..Im thinking she broke
well..seemings u asked...lolMaybe.
Seemed like were only three guys that ever commented.
1 was helpful...lol.
What was your deleted post about?
Sent from my SM-N960F using Tapatalk
shoot my bad ,,I miusta missed your questions..so here we go.*updateWere you able to see my last post with the questions I asked?
My questions were:
1. Have you tried another key/fob to try and start the car?
2. Is the fuel pump shutting off? Does the engine stutter like starving fuel or run ok and shut off? See if you can check the fuel pump relay to check voltage driving it. If you have vcds, you can turn on/off the relay with the software.
3. Check your battery voltage. And make sure you don’t have any grounds that became loose when you changed out the motor.
Let us know. Dont throw in the hammer yet. Never give up. I am still (6 months later) trying to figure out a p0011 code on my 2005.
Matt
can you maybe elaborate aliitle bit on what the differences would be? You are correct tho, when i purchased the engine it never dawned on me to check that. Fitment was checked by vin..now im curiousAre you sure you replaced the motor with the same designation as the original. AEG, BEV, BBW. The letters are called out on the timing belt cover.
Just asking the question because someone not in the know could have just bought a 2.0 from the same year and not realized there is a significant difference and the ecm won’t like it
this is the error Im getting nowcan you maybe elaborate aliitle bit on what the differences would be? You are correct tho, when i purchased the engine it never dawned on me to check that. Fitment was checked by vin..now im curious
Ok so , this engine was replaced once before I took ownership, and I never thought to check if the first swapper installed the correct engine. So I went back to the chassis itself and verifide that the engine code from factory was AEG. The engine that I installed is Engine 2.0L Gasoline VIN T 5th Digit Engine ID Aeg Fits 98-01 BEETLE. Fifth digit of my vin is C..do you see a conflict anywhere that I should maybe take a look at? Thanks for helping me with this.That controller number is the ecm. That number refers to a 2000-2001 jetta 2.0l with automatic. AEG should be the engine code that is in your car
Controller: 06A 906 018 JJ is my ecm correct?The ecm looks for different feedback from sensors, etc on the different engines. If you post the number off of your ecm, should be able to tell you what engine should be in car and tranny, etc.
Let me know
may i ask how 06A 906 018 JJ translates to 2000-2001 jetta 2.0l with automatic. AEG ? plzOk so , this engine was replaced once before I took ownership, and I never thought to check if the first swapper installed the correct engine. So I went back to the chassis itself and verifide that the engine code from factory was AEG. The engine that I installed is Engine 2.0L Gasoline VIN T 5th Digit Engine ID Aeg Fits 98-01 BEETLE. Fifth digit of my vin is C..do you see a conflict anywhere that I should maybe take a look at? Thanks for helping me with this.
