Hello!
Having problems setting up my timing on my car after my timing belt broke and bent a valve. I've searched on the forums for a good answer, but haven't been able to find it, so im gonna post my problem, maybe get some help.
like i said, timing belt broke on my 2005 2.0, bbw engine. After doing a valve job on the head, put it back together and started doing the timing. Put the locking plate in the camshaft to line it up for tdc, and then went looking for the mark on my flywheel...which i cannot see. Its just too rusty and its not there anymore.
I can place the piston 1 at TDC by way of putting something in it to find its highest point.
My question is, should it be at its absolute highest point, or should it be barely starting on its downstroke to set the timing?
Without that mark on my flywheel, its more of a guessing game to get this timing right, plus the added nuisance of having to take the valve cover off just to set the camshaft
on this bbw engine
I'm just trying to cover my bases on this before it turns into a bigger problem
Thanks for any and all help!
on this bbw engine
