1 - 6 of 6 Posts
THE HORN ON MY 2017 JETTA 1.4 L ENGINE SOUNDS SO LAME THAT NOT EVEN A MOUSE COULD HEAR IT . DID ANYONE CHANGE THE HORN . I KNOW IT HAS TWO BUT I WANT TO CHANGE THE ONE THAT SOUNDS WHEN PRESSED ON A STEERING WHEEL . THANK YOU
They both sound from the steering wheel one is a high tone and the other a low tone so you should change them both and it’s not hard to do
Thank you Dashe , you said not hard to do can you suggest how or who to go to ? thank you for all your help, Bill
All you need to do is get the horn that you want and mount them where the original ones are and cut the plug off and put on the correct fittings for the new horns I recommend testing which is the positive and negative prior to cutting the plug off then plug them in and you are done and they work just like factory but louder
1 - 6 of 6 Posts
