Injectors would be completely pointless unless u have the ignition system to back them up and u also need a fuel pressure regulator but to add that to a stock car would be pretty much completely pointless in theory.
^ That backs up my moving into forced induction theoryInjectors would be completely pointless unless u have the ignition system to back them up and u also need a fuel pressure regulator
I think an intake and a chip would perk it up just right for you. There is sooo much you can do to your engine/car. The best feature of the TDI engine is all the torque you get. That makes for a fun motoring experience with the right setup.yea defintly not right now its gonna be my gf's. and she does not need that much powerat all.but i want something to play with cause i drive a f100 lifted so yea
The only reason i can think of to replace injectors is if they are broken or you are putting bigger ones in for power purposes. Since we are talking about mods, i assume the second is the case. Bigger injectors damage mpg, so i'd avoid that til everything else is done.chip and injectors will mak ea huge difference in power, but it wont hurt your mpg
Bigger injectors will not damage the MPG unless you change the way you drive the car in such a way that you're calling for more fuel. If you drive sensibly and get chipped with bigger injectors your MPG can actually go up BUT you have more power when needed and that's when you burn more fuel than you would have with stock injectors. Check the club, you will get your answer there.The only reason i can think of to replace injectors is if they are broken or you are putting bigger ones in for power purposes. Since we are talking about mods, i assume the second is the case. Bigger injectors damage mpg, so i'd avoid that til everything else is done.
Mainly, bigger injectors allows for more fuel consumption , even though the driver to car interface doesn't change.
