so i have heard you can cut the bead out of stock steelies flip the face of the steelie around and weld it back to create your own widened steelie. lots of people have done it, i just cant find the right info.
any one experienced?
seen it done?
Not something anyone can just do. Has to be cut and re welded perfect. If its not perfectly centered and balanced, you can have lots of problems getting the wheels to balance out and could have some bad vibrations.
Iv never heard of doingthis but gonna have to look into it!! I have a few machines at my school I could use to cutit (plasma cutter or others) and I know a lot of good welders seems almost to simple!!
its not simple. Not at all. Precision equipment is required as well as a precise measuring equipment like laser guided and assisted mount and balancing machines.
i have seen some pretty low tech ones being done, its helllla old school,
just some basic measuring, if you have a spare axle, bolt em up to it and true them out before welding em, its actually something within our grasp (assuming youve welded for a few years).even if you havent a cheap welder is worth its weight in gold
heres another alternative.
i can post some more links here shortly, i might start crackin these out after i practice on some old steel, and sell em to get the bunk ass vw scene cookin around here. its overrun with jdm in my spot (but these hondas are getting sooo legit, i might pick one up and du werke)
I'm a certified welder, been doing it for about 7 years now.. I have been threw a year of classes just based around machining as well, and I still wouldnt do it. Like Das said its not simple by anymeans. There is a reason you pay so much for other people to widen them... IF your just using them for show (drive somewhere, swap wheels then do a mile cruise in stop and go traffic I MIGHT consider it... But I would never daily on DIY widened steelies unless they were done with the right equipment
But then again I have had a wheel break, and another wheel fall off at 80+
yea im a welder too, people have been doing this since our parents were in diapers, most of the links i posted are ppls daily drivers, i think it can be done. balancing is really not too complicated. "measure twice cut once" type stuff.
I know this is an older thread, but i HAVE done this to one of my older rock crawlers. recentered H1 double bead locks. i could cruise down the highway at 70 on 38's with ZERO vibration. I made up a couple jigs to help me keep everything in check. 1 wheel i had almost a 1/32nd run out....
Dont have any pics of the jigs, but I used an old hub i had laying around. Set up my back spacing, tacked the wheel to some 1/2" plate steel, tacked in the new center, used the truck itself, put the wheel on, used a digital dial indicator to measure run out. few whacks here and there to get it dead nut. full welded the centers in, in a star pattern. Rechecked run out, and the most i had was the 1/32nd. heres a pic of my old crawler
i dig it^
so im just gonna get a hub for the mk4 and hook it to the lathe, cut the beads, mount the face to the hub, and scooch the barrel back about 3 inches, true up and re weld. is that similar to how you did your jig? thinking about doin some audi spares, into some wide truck rim barrels
LMK
A guy about 4 hours from me widdens steelies he's 87 years old 120 pounds lol, and I'm pretty sure his equipment built the Bismarck . For $500 he does all 4 wheels and that's ready for paint. I know of 6 guys who had this done from mk1s to mk5s. It's amazing watching this frail old man rolling steel in an English wheel.
Related Threads
Volkswagen Jetta Junkies
295K posts
41.3K members
Since 2007
