As the title states. PM me for add-ons.
Engine/Mechanical
General
Swiss Cheese Mod
Removing downpipe & replacing Cat on 12v VR6
Wooden Jack Pad
Manual adj/removal clutch cable
Clutch Replacement
Key FOB programming
Finding a Vacuum Leak
Coilpack replacement 12v VR6
12V VR6 Gruvenparts Pulley Set Install
MK5
Cabin Pollen Filter Replacement
MK4
motor mount replacement
Door Lock Fixes
Replacing Cabin Filter
Running sub wires guide
Turbo inlet pipe install
Seafoam: 1.8T
Seafoam: VR6
Coolant Flush
Replacing lower intercooler pipe 1.8T
Cleaning throttle body VR6
Climate Control Lamp Replacement
Cleaning your MAF
Another MAF cleaning method
Radio Codes
Fuel Filter Replacement
Intake Install
Clutch/Flywheel/Pressure Plate Replacement
Disabling DRL's
1.8T Crankcase Ventilation System Replacement
MK3
Rear coilover install
Coilover Installation
Short Shifter
Short Ram Intake
Heater Core Removal
Heat shield + Air duct
ECU Chip Installation
Bypass Factory Alarm
Front Coilover Installation
Rear Coilover Installation
MK2
Heater Core Removal
Cold Air Intake
Digifant: All You Need To Know
Cosmetic
General
Painting techniques PART1
Painting techniques PART2
Fixing cracked grille
Tinted Tails
Paint your grill
MK5
Removing and Painting Shift Bezel
MK4
A/B/C Pillar Removal
Rieger shift knob installation
Shift knob replacement
Stubby Antenna install
headlight removal
Taillight Removal 5th brake/rear fogs DIY
Front Bumper Removal
Rear bumper removal
Joey Mod
Hood Notch Fill
Removing your Rear VW Emblem
Antenna Base Replacement
Double Din head unit install
Another double din headunit install
Installing CCFL Lamp
Rear Fog Lights
HID Retrofit
MK3
Joey Mod
Removing tail lights
Replacing lock pins
Mesh Grille
All Red Taillights
Ecode installation
Euro tub installation
AC/RECIRC and rear defrost, how to change the color of the lights
MK2
Shaved Big Bumper
Single Wiper Arm Conversion
LED Turn Signals In Mirror
Engine/Mechanical
General
Swiss Cheese Mod
Wooden Jack Pad
Clutch Replacement
Key FOB programming
MK5
MK4
Door Lock Fixes
Seafoam: 1.8T
Seafoam: VR6
Coolant Flush
Cleaning your MAF
Radio Codes
Intake Install
Disabling DRL's
MK3
Short Shifter
Short Ram Intake
Heater Core Removal
MK2
Heater Core Removal
Cold Air Intake
Cosmetic
General
Tinted Tails
Paint your grill
MK5
MK4
headlight removal
Rear bumper removal
Joey Mod
Hood Notch Fill
Rear Fog Lights
HID Retrofit
MK3
Joey Mod
Replacing lock pins
Mesh Grille
All Red Taillights
Ecode installation
MK2
Shaved Big Bumper
