its interesting that cylinder 2 and 6 are misfiring, there both not connected to the same coilpack, first off are you running a resistor with the msd setup? second is your spark plug wires completely pushed down?
Thanks for the response! I'm not running a resistor. I heard that it wasn't necessary so I didn't bother; I haven't had any problems from them either since I put them in. I'm pretty sure the wires are completely pushed down, but it would be great if that's where my problem is. I'll have to check it out. I thought it was weird too that 2 and 6 are misfiring. Aren't 2/5, 3/4, and 1/6 grouped together?its interesting that cylinder 2 and 6 are misfiring, there both not connected to the same coilpack, first off are you running a resistor with the msd setup? second is your spark plug wires completely pushed down?
Yes the resistor is not necessary and actually seemed to be the cause of blowing coils, the grouping is correct I really can not think of what I could be but pull the wires and hook up a multi meter to see if your getting a signalThanks for the response! I'm not running a resistor. I heard that it wasn't necessary so I didn't bother; I haven't had any problems from them either since I put them in. I'm pretty sure the wires are completely pushed down, but it would be great if that's where my problem is. I'll have to check it out. I thought it was weird too that 2 and 6 are misfiring. Aren't 2/5, 3/4, and 1/6 grouped together?
Was just messing around on it for a little before I had to go in to work. Decided to check the codes again and this time it said only cylinder 2 was misfiring. Weird.Yes the resistor is not necessary and actually seemed to be the cause of blowing coils, the grouping is correct I really can not think of what I could be but pull the wires and hook up a multi meter to see if your getting a signal
Man you have me puzzled nowWas just messing around on it for a little before I had to go in to work. Decided to check the codes again and this time it said only cylinder 2 was misfiring. Weird.
17646 - Fuel injector for cylinder 2 (N31) open circuit p1238 - 35-00
16684 - Random/multiple cylinder misfire detected p0300 35-00
16686 - cylinder 2 misfire detected p0302 35-00
However, it gets stranger. Thought to clear out the codes and see if it would act up after that, but now it won't start at all. Charged up the battery to see if it was that but was not the case. Now I'm getting...
18011- Internal Control module: failed self-test p1603 35-10 -- Intermittent
I got it started. I disconnected the positive lead before I went to work hopping that it would reset the Ecu by the time I got back. Eight hours later I hook it back up and throw a charge on it and it runs now but still have the misfire on two. Checked the fuses again and they were fine. Think I'm going to take it apart again and check out the injector on it. Again. Hopefully I just overlooked something small.I would bench test the starter
I had tried swapping the wires but cylinder two still was misfiring. The plugs are brand new and I checked to see if volts are running through them. What do you mean by the gap but though?are the plugs correctly gapped at .028? also hows the condition of the plug wires? maybe try switching #2 wire w #5 and see if the misfire changes to #5 cylinder, if so the wire is bad
this. any spark plug gapping tool can be purchased from an auto parts store for like $2. the gap is the measured distance between the metal prong and the metal tip on the ceramic base. if the gap is off a little it'll still run alright but not at its peak and if the gap is way off(anything above a .010 variance) it'll run rough an probly show up as a misfire on that cylinder. since you are unaware of the gaps then my first thought leans towards an incorrectly gapped plug on cyl 2. they say plugs are pre-gapped from the factory, never trust that. also what brand/style plugs are you using, oem?Spark plugs are gapped from the tip to the metal part that sticks out on top, check that gap and see if it's .028
actually the NGK BKR5EKU(nickel plated)are the oem recommended plug, and it works the best hands downFYI Ngk iridiums are recommended for vr's
Yes they are the oem but I've read most recomend the iridiums with the msdactually the NGK BKR5EKU(nickel plated)are the oem recommended plug, and it works the best hands down
