1 Headlight, Low Beam, Left 10
2 Headlight, Low Beam, Right 10
3 License Plate Lights 10
4 Rear Window Wiper And Washer System 15
5 Windshield Wiper/Washer 15
6 Fresh Air Blower, A/C 20
7 Tail Lights, Right 10
8 Tail Lights, Left 10
9 Rear Window Defogger 20
10 Fog Lights 15
11 Headlight, High Beam, Left 10
12 Headlight, High Beam, Right 10
13 Horn 10
14 Back-Up Lights 10
15 Engine Electronics 10
16 Power Sunroof, Front Map/Reading Light 15
16 Emergency Flashers 10
18 Fuel Pump (FP), Heated Oxygen Sensor (HO2S) Control Module 20
19 Coolant Fan, A/C Relay 30
20 Brake Lights 10
21 Interior Lights, Clock, Luggage Compartment light 15
22 Cigarette Lighter, Radio, Luggage Compartment Release 10
Fuse colors
30A Green
25A White
20A Yellow
15A Blue
10A Red
Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 357 937 039)
Connections and plugs on rear of fuse/relay panel:
A1 Yellow 8 pin Headlight wiring harness
A2 Yellow 8 pin Headlight wiring harness
B Green 6 pin Headlight washer wiring harness
C Yellow 8 pin Headlight or wiper motor wiring harness
D Green 12 pin Miscellaneous equipment, varies (A/C, A/T, heated seats, seat belt warning, etc.)
E Green 5 pin Instrument or brake light wiring harness
F White 10 pin Engine compartment/engine management, wiring harness, right side (position 10 open)
G1 White 12 pin Engine compartment/engine management, right side
G2 White 12 pin Engine compartment/engine management, right side (position 12 open)
H1 Red 10 pin Steering column switch wiring harness
H2 Red 8 pin Steering column switch wiring harness (position 8 open)
J Red 10 pin Steering column switch wiring harness
K Black 12 pin Rear wiring harness
L Black 8 pin Rear/Parking brake wiring harness (position 8 open)
M Black 6 pin Rear/fuel tank wiring harness
N Green 6 pin Air conditioning wiring harness
P Blue 10 pin Rear window defroster/fog light wiring harness
Q Blue 6 pin Fresh air blower fan wiring harness (position 10 open)
R Blue 10 pin Light switch wiring harness
S White 5 pin Engine compartment/wiper motor wiring harness, right side
T Green 2 pin Individual circuits
U1 Blue 14 pin Instrument cluster wiring harness
U2 Blue 14 pin Instrument cluster wiring harness
V Green 4 pin Steering column switch Multi-function indicator wiring harness
W Green 6 pin Miscellaneous optional equipment, varies with vehicle type
X Green 8 pin Warning lamp wiring harness
Y n/a 1 pin 4 single point connectors for terminal 30 circuit (some may be bridged with red connector)
Z1 n/a 1 pin Single point connector
Z2 n/a 1 pin Single point connector for terminal 31 circuit
30 n/a 1 pin Single point connector for terminal 30 circuit (may be bridged to 30B with red connector)
30B n/a 1 pin Single point connector for terminal 30 circuit (may be bridged to 30 with red connector) Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
