4K views 6 replies 3 participants last post by  charles.ottinger
#1 ·
Hello everyone! So i have a 2001 vw jetta 2.0 and when i bought (10/5/14) the check engine light has been on. the previous owner said they had the transmission rebuilt for like $3k. Since i Had the car it drove fine but now my tranny is slipping when ever i slow down to like 5mph or when i shift from park to drive or reverse to drive the car will sit there and not roll. In fact I believe its in neutral cause i can push the car forward and backwards. I had the transmission fluid check and my mechanic says it good. I believe its the ECU cause i have 10 codes.
P0411- Secondary Air Injection Incorrect Upstream Flow Detected
P0442- EVAP Control System Small Leak Detected
P0261- Cylinder Injector Circuit Low/Short to Ground
267
270
264
P0445- Evaporative Emission System Purge Control Valve Circuit Shorted
P0418- Secondary Air Injection Relay (A) Circuit Malfunction
P1472- EVAP Emission Control Leak Detection Pump Circuit Short to Ground
P0606- ECM Internal Communication Error
So as you can see now transmission codes at all. If i have to rebuild the tranny again that's gonna suck. Also my friend says my transmission could be slipping from racing in the car and using gears 2 and 3 when ever i want to pass some one up.
