1 - 12 of 12 Posts
Discussion Starter #3
Lift specs are
-Front-
Mk4 Vr6 struts
Mk5 strut mounts
Jeep wrangler jku front coil springs
Front stabilizer bar removed
Audi tt 225 solid control arm bushings
meyle-HD ball joints
-Rear-
Cupra R rear beam bushings
Jeep cherokee xj coil springs
99 ford f150 rear shocks
-Wheels and tires-
Stock 16" steel wheels
Winterforce 215/60r15 studded snow tire
-Body mods-
Front bumper removed for added clearance
2000lb winch (will be getting upgraded to a 12,000lb soon)
13" LED light bar
2" 4" LED light pods
2 2" LED flush mount pods in rear bumper
-Interior-
Gls seats with beetle head rests
NRG steering wheel hub adapter
NRG gen 2 steering wheel quick release
NRG blue steering wheel
Column mount single gauge pod
Glow shift 30 psi boost gauge
Kenwood bluetooth head unit
2 sundown audio 12"s in rhino lined ported enclosure
-engine n driveline-
90k mile 1.9 alh engine
Race pipe
EGR delete plate
EGR cooler deleted
2.5" straight pipe to magnaflow muffler
Full A/C system delete
BEW 5 speed transmission
White powder coated valve cover
Discussion Starter #4
If your interested you can find more content of the lifted tdi on fb
@https://www.facebook.com/LowLyfeLiftedJettaTDI/
Instagram
@_eurotrash2020_
YouTube
@https://youtube.com/channel/UCPQ9pmtxOFJzEosPkG_2GzA
My personal fb
@https://www.facebook.com/profile.php?id=100036716820318
Discussion Starter #6
Currently down for more mods. This round it's getting-
Steel bottom hybrid oil pan
Ecs magnetic oil drain plug
Diesel geek panzer plate with fmj sides
Snorkel
2.5" Hood stack to 6" miter cut tip sticking out about 4" from the hood
Getting painted semi gloss black
Getting some zombie outbreak response team decals put on it
Fender flares
Basette d hole bs bead lock 15x8 5x100 4" back space matte black wheels with the bead locks powder coated green and chrome hardware
Forceum mt08 235/75r15 mud terrain tires
Lug stud conversion
Steel red spike lug nuts
Red spike valve stem caps
Roof rack with basket
Roof rack, basket, fender flares are being rhino lined
Discussion Starter #7
38470
Using rust-oleum semi gloss black paint. I off-road the car I expect the paint to get damaged and scuffed, this way I can fix it myself at home in the garage.
38474
38472
38473
Zombie outbreak response team decals for the jetta once it's painted
1 - 12 of 12 Posts
