1 - 6 of 6 Posts
my turbo seals are going out on my k03. i will need to either replace the turbo with a new K03 or possibly upgrade it to the K04 if it will bolt right up to the stock parts. I was considering getting a turbo rebuild kit but i'm not sure what the actual part number is for the stock turbo because i do believe there are several different types and some are for the passat, etc and won't interchange, any help would be great thanks!!
also wondering if the K04 will require a fmic, or any other upgrades??
Senior citizen member
AFAIK there is two different type of internalsfor the k03s and the only way to know for sure would be opening the turbocharger and looking
A front mount is not required but is definitely a good idea to keep the temps low thus making more power, if going k04 there is a model that bolts right in and uses all your factory parts but I cant remember the part number
frankenturbo will require some rods or torque spikes will kill your motor...k04-001 is straight bolt up.. and theres some tunes out for it to get the max out of it..unitronic etc.
1 - 6 of 6 Posts
