Hello all! New member here. My girlfriend has had her MKIV 1.8T Jetta for about 2 years now and she loves it... when it's not being a pain in our asses. Our latest endeavor with her baby has now somehow left me with a clutch engagement problem. About 4 or 5 months ago my buddy (who is a technician), and myself did a stage 1 clutch replacement, along with a new fork, throw out bearing, and single mass flywheel conversion. Everything went smooth except I managed to break the speed sensor. My bad... Anyways I just now got around to fixing it and was successful... sort of. When I finished I went to remove the car from the garage and test it out, but I noticed the clutch was only moving 3-4 inches at the most. I picked the pedal up with my toe and then it felt better, but now my clutch will only engage at the tippy top of the pedal. I took it for a test run to see if it was good, aaand it started slipping. Tried bleeding and I also pulled off the slave and it looked fine. I'm not completely sure how to tell if the slave cylinder is bad, but if I am retaining pedal pressure and there are no tears in the boot or leaks, I'm assuming it's okay.
I have no idea what I did to cause this problem and the same friend who helped me with the replacement is stumped too. Is there anyone who has had a similar problem and could maybe give a fix suggestion? Not trying to land in the dog house tonight! Thanks guys!
