1 - 1 of 1 Posts
Hi have a 2001 Jetta Wolfsburg It will not go into 5th. Running or not running Had tried to Adjust the cables no luck
Prev owner says he did not have problem I toe dollied it 700 miles after purchased
I did not drive it before trip, my mistake
shift lever on transmission just will not go UP enough to allow it to go into 5 th if i lift it up then it will go into 5 th
Sounds like Adj but tried it twice
going to check the little white plastic piece on lever that the ball goes into ?
need help in Forest park Cincinnati Ohio
Thanks
[email protected]
1 - 1 of 1 Posts
