1 - 7 of 7 Posts
I recently saw that the engine block light came on my VW Jetta 2007 GLI. I went to an AutoZone and the code P2181 came up, referring to cooling system performance. The reasons were low coolant, failed radiator/water pump, and or ECT sensor.
The coolant was well above the minimum amount. I just got my water pump replaced (as part of the timing belt kit) back in early March. From researching online, I've seen quite a few instances where the problem was solved by replacing the thermostat. That is something I wouldn't mind doing myself, but I don't want to spend money to go to a auto shop and or dealer, where they charge 100 bucks just to diagnose it and that doesn't include the parts and labor. I saw a thermostat is around 30 to 50 bucks online.
Anybody else have this issue before? And if so, what did you do to resolve it?
Thanks for the help in advance! :)
An engine coolant temp. Sensor is what I have relaced in the past and much cheaper and easier to do than a thermostat it is the sensor for the computer.
I know this is elementary, but I hear the fans moving. I just can't locate them. Are the fans located at the same place for all Jetta's? I have a 2007 Jetta GLI
Thank you
Nevermind. I did find the fans. I guess I was looking for something else. The bigger fan is moving but the smaller isn't moving when I initiate the engine. Is the second one suppose to kick in right at the beginning when you start the car or does it kick in later when you're driving?
Asshat Patrol
They should both be moving.
Is it overheating?
1 - 7 of 7 Posts
