I managed to startup the car a couple days ago. After the valve cover gasket replacement, I was expecting smooth sailing.
That'd be too easy!
Here's the short end of the stick:
P0300 - Random Misfire
P2295 - Fuel Pressure Regulator 2 - Control Circuit Low
P0458 - Evaporative Emission System Purge Control Valve Low
P0245 - Turbocharger Wastegate Solenoid Low
P2401 - Evaporative Emission System Leak Detection pump control circuit low
P0304 - Misfire in Cylinder 4
P0302 - Misfire in Cylinder 2
P0031 - HO2S Heater Control Circuit Low (Bank 1, Sensor 1)
P0036 - HO2S Heater Control Circuit (Bank 1, Sensor 2)
I've done quite a bit of research on Engine-codes.com... and the Repair Difficulty Level is at 3 (Hardest). But given the fact that i'm willing to do it myself. Chips all in.
Where would I even begin?
That'd be too easy!
