So i've got some problems that i need addressed and some that i need information on where i can get the part i need.
Problems...
1)Vaccum Leak due to cracking vaccum line (need to know where i can get this part)
2)when raining or driving through sizeable puddles my car will sometimes emit a screeching noise and shortly afterward my battery light comes on and my power steering pump goes full retard (on off on off ect...). (this only lasts for 5 seconds tops)
3) car makes a weird droning noise when i get up to speed. not sure where the problem is here.
4) transmission had down syndrome. when i swich from park to reverse it will normally take 1 second to engage but sometimes takes up to 5. Also the same problem persists when switching from reverse to drive... my car also absouloutly refuses to shift below 3k rpm's. AND when accelerating the change between gears can sometimes be rather... harsh
5) turn indicators pick and choose when they want to work. i've found a way to get them to work when i flash my high beams then use the turn indicators and i'll just repeat doing so untill they decide to work
6) car consumes a quart of oil every 2000 or so miles.
7) Misfire in cylynder one. proabably due to the vaccum leak.
so guys... what would you say to these unfourtanate annoyances? how would i fix them? what are they? where can i get the part?
and yes... i most definately have a CEL.
Problems...
