Hi - Does ANYONE have a DIY for replacing the radiator on 2000 Jetta GLS?? Have the radiator in hand now but want to be SURE to do it right.
HELP :):eek:
HELP :):eek:
jack the car up
take the front end off
drain the radiator
undo the fans from the rear
undo the radiator from I believe the front, then swap em and do the steps in reverse
If you can take the hole radiator mount off I would do that but that means you have to crack open the ac lines
