Hello everyone!
As I just purchased my Jetta used, it has the Viper 7153 remote start installed.
I know the proper start sequence, for when I need to start via remote.
However, I know with the key having the chip in it... the system will not keep the car running.. It will crank, but that is it.
If I keep the key in the ignition, everything works just fine.
There are two wires going around the actual ignition switch, to represent the correct code ( so I assume ) when the actual key has been removed.
Any suggestions?
Thanks,
Jeff
Any suggestions?
Thanks,
Jeff
