Hey, I have a 94 Jetta 2.0. The temp gauge maxes out even before I turn the engine over. I have replaced the water pump and thermostat. Then I replaced the temp gauge sensor unit and it still maxes out. I don't know what else it could be. Any help would be awesome.
Could be a fault with the gauge itself. You've replaced everything that (typically) causes overheating, but because it's ''maxed out'' when its not even running... Thats probably a gauge problem.
You can replace the gauge cluster, or hook up an auxilary temp gauge too.
