2004 Volkswagen Jetta 1.8T any advice would be nice I would just like to get one of the right direction if possible this is my readout
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: Release 22.10.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Sunday,12,February,2023,15:43:49:00009
VIN: 3VWRE69M64M026992 License Plate: AFB336
Mileage: 187376 Repair Order:
Control Module Part Number: 06A 906 032 NK
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 07500
Work Shop Code: WSC 00066
VCID: 74E769D744BB262D96-5178
Additional Info: 3VWRE69M64M026992 VWZ7Z0C7856288
14 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-10 - Mechanical Malfunction - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 -
16395 - Bank 1: Camshaft A (Intake)
P0011 - 35-10 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
16621 - Manifold Pressure / Boost Sensor (G31)
P0237 - 35-10 - Signal too Low - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 35-10 - Implausible Signal - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
18011 - Internal Control Module
P1603 - 35-10 - Failed Self-Test - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-00 - Misfire Detected
Readiness: 0110 1101
VCDS
www.Ross-Tech.com
Dealer/Shop Name:
14 Faults Found:
P1297 - 35-00 -
P0300 - 35-00 -
16685 - Cylinder 1
16688 - Cylinder 4
16686 - Cylinder 2
16687 - Cylinder 3
