I run power down one side of the car, and the audio cables on the other side.
Pull your door foot sills, there should be a channel to run wires to the trunk,
ASSUMING that's where it's going. Pull your rear trim out so you can run
any wired behind it.
Depends on how much work you want to put into it. Usually I run everything through the sides tucked under the carpet, but when I bought my Jetta the previous owner already had the wires ran, so I pulled up the carpet and removed all of it then ran my own down the middle under the center console to the trunk.
If you look above your brake pedal, you should see a big rubber grommets on the firewall. I put a small hole in it and ran my wire from there.
Related Threads
Volkswagen Jetta Junkies
295K posts
41.2K members
Since 2007
