Don't know what a cam costs but DO get an OEM one, or from a reliable maker/seller like NAPA. And when you install it be sure to buy a set of cam followers. This isn't the time to go inside and AutoZone!! And they're not "lifters" as people call them.
IMPORTANT: "Replacing the cam" isn't a simple matter of throwing a cam in it. You MUST take note of the timing marks on the cam and crankshaft sprockets so that whne you're all done you won't trash that "interference" engine!!! Rolling the engfine over BY HAND is a must after you're all done, to insure nothing's hitting inside! Most people on these forums make a big deal out of replacing the timing belt on these cars, but it's not that big of a deal IF you take note of the cam/crank timing mark position before AND after you do the job. OH - and while you're at it, replace that timing belt too!!!
And when it's all done be sure to add a couple cups of LUCAS oil additive to your oil. That will keep the cam and followers lubricated after you shut off the car. Look at one of their display at any Oreilly's auto parts store. It's really cheap insurance against a failed valve train. No olil in the world will lubricate diddly squat if it's not ON what needs to be lubricated!!!!
