VW Jetta: 2019 Jetta Speedometer connector schematic/pinout needed|Forum Volkswagen Bora
Results 1 to 3 of 3
Thread: 2019 Jetta Speedometer connector schematic/pinout needed
    Default 2019 Jetta Speedometer connector schematic/pinout needed
    hi everyone,
    i am working on a 2019 Jetta that was in a collision. the vehicle cant be powered up, but i need to power up the speedometer to determine mileage.
    the speedo main label in center has the following info
    17A920 840A 2700
    kombiinstrument 17a 160 then further over 252
    immobilizer GEKOWFS2
    the harness has a pink lever and the following color wires
    black
    green
    brown
    purple w a white line
    brown w blue or grey line
    black w purple line
    red w green line
    the last 2 are rotating close together (no visible wires touching in harness)
    green wire
    orange w thin black line
    any ideas what 2 wires get 12v and what polairity?
    I dont want to assume the black is gnd and red w green are the power and smoke it.
    thanks,
    John
    JettaJunkie.com
    Advertisements
    Nov 2009
    Middletown, DE
    13,635
    Default Re: 2019 Jetta Speedometer connector schematic/pinout needed
    on vw's brown is ground, and per the pin out brown is ground and the red with green tracer is 12v power this comes directly from fuse 17 which is a 7.5 amp fuse
    hope this helps
  4. #3
    Quote Originally Posted by Skimmer0220 View Post
    hope this helps
    THANK YOU!!! WORKED GREAT
    I tried to insert the image but the image icon could not be clicked, tried drag and drop but that didnt work either
    if you can tell me another way to upload a photo ill provide an image of the mileage for you if you are interested.
